This document provides an overview of the various reports that are automatically generated by Maven Each report is briefly described below.
Document | Description |
Change Log | Generated change log report from SCM. |
Checkstyle | Report on coding style conventions. |
Developer Activity | Generated developer activity report from SCM. |
File Activity | Generate file activity report from SCM. |
FindBugs Report | Generates a source code report with the FindBugs Library. |
